on 01-06-2020 16:12
I have an intermittent problem when receiving calls on my mobile. I can hear the caller but they can't hear me. Often they hang up and call back and this fixes the problem. I also try restarting my handset but the problem still recurs.
I use a galaxy A10 handset but also tried the SIM in an iPhone 5s and got the same problem.
It has happened in different locations and at with different callers. It is not a signal issue as the call connects fine but there is absolutely no sound at all from the start of the call.
It's having an affect now I'm working from home and I am missing work calls. Help please.
on 09-03-2021 13:46
Thank you for coming back to us.
Please could you try an manual network search and let me know if that works?
Could you also provide me with a local post code (a shop etc) so that I can take a look over the masts in the local area.
Kind regards,
Zak_M
on 09-03-2021 13:54
I have disabled wifi calling but that didnt work. I called customer services who advised I would need to switch off wifi every time I receive a call as it must be interfering with incoming calls, which is ridiculous to expect. The other solution was to cancel my contract within 14 days before I become tied in and this problem remains unsolved (as in other peoples cases)
I am in the BB1 area, and I understand Virgin uses the Vodafone network which was the network i have switched from (and never had issues with).
Sorry but I dont know what a manual network search entails?
on 09-03-2021 14:14
on 09-03-2021 14:37
Ok so I did a manual network search, selected Virgin and text one of my contact to call me. They said the dial tone sounded strange and they couldnt hear anything when I answered. As before, I could hear them fine.
Reading about this issue I'm beginning to think there might have been a problem with the porting process when I joined Virgin.
on 09-03-2021 14:39
Sorry didnt realise that it wasnt meant for me, it didnt work in any case
I've requested a pac code but I havent used it yet as I was going to look around for a sim only deal first.
If the issue is resolved in the next day or so I'd be happy to stay with Virgin.
on 09-03-2021 15:46
Hi Rehana06,
Thank you for reaching out to us in our community and welcome, I am sorry to hear you cannot hear callers, can you try and turn off WIFI calling off or even WIFI itseld while you make a terst call?
Paul.
on 09-03-2021 16:51
Hello Zac_M
Still using Virgin mobile, going to give it a chance to sort things out, but if nothing happens I'll have no choice.
The issue occurs anywhere from North London, to Somerset, Dorset and Gloucestershire, its not localised issue. Signal wise it can occur with ful signal, or a single bar, similarly somtimes the fault does not occur and I have normal usage with a single bar of signal.
I'll try to switch automatic selection off, persumably manual will make it default to Virgin mobile?
on 09-03-2021 17:14
Hi WC14,
Thanks for coming back to us, please let us know how you get on once you have set your phone to Automatic connection.
Paul.
on 24-03-2021 11:46
Hello - I am having same problem, switched to Virgin from Vodafone about 4 weeks again and callers could not hear me but I could hear callers, when I called back then everything was OK. I have a phone which allows a dual sim so after a week of frustration I moved the sim card to the other slot and everything was fine for 2 or 3 weeks. This morning the problem came back. I have called Virgin and they are sending me a new sim card, in the meantime I have switched the sim back to the original slot and it is now working again.
Frustrating and does not inspire confidence in Virgin product.
Hopefully the replacement sim will solve the problem.
on 24-03-2021 13:39
Having the network selection set at automatic or manual makes no difference.
I have eliminated the handset, as the handset works fine with a different Virgin Media SIM card. It is network related, not handset or SIM related..
Paul.
