Davidjames123
Permanant R above signal bars / no mobile data
I received a new purple sim to replace my old SIM card, as my old one was too old and a capital letter R has appeared permanently above my signal bars. I am a pay as you go customer and I was told over the phone that I should needed to insert the new sim once I’d received it and it would work the same as my old one. I can still make calls and receive calls and text but I’m a bit concerned that I will be charged as I know some networks do charge for roaming data even though I’m still in the UK. Can anyone please help me out? Thanks
JitteryPinger
  • 1.87K
  • 207
  • 393
Super solver
Re: Permanant R above signal bars / no mobile data
What device do you have the sim in please
If I've helped let me know 🙂
10 year's managing 9 Virgin Media accounts, and things never got any better, closed last 4 accounts since January 2021 :L
I give 'my' experience to help where possible.
enlli
  • 8.45K
  • 1.3K
  • 2.42K
Some old devices (seen it in Nokia and early versions of Android will display an R)
What device are you using
Chris_W1
  • 4.41K
  • 200
  • 286
Hi Davidjames123, thanks for the message. I am sorry to hear hear that you are having issues with this can you confirm the make and model of the handset you are currently using? ^Chris.
