Hi Hannahprescott6,
Thanks for your post and welcome to the forums. It's great having you on board with us.
Apologies to see that your order has been parked. Usually this means we need to double check a few things with you before we can accept the order. The team will be in contact with you however if you need to speak to someone asap then give them a call on 0345 600 078 for them to check things for you.
