Sign in
Sign out
on 13-05-2021 10:06
Hi I have 3 phone numbers that I want to switch to another supplier. I requested PAC codes and was given the same code for each number. The new supplier says that I should have a different one for each, is this correct?
Cheers
Answered! Go to Answer
on 13-05-2021 12:09
This has come up before
https://community.virginmedia.com/t5/Virgin-Mobile/Strange-PAC/m-p/4687138#M192555
Virgin say it is possible, other networks say no.
Found this answer helpful? Share it!
on 13-05-2021 12:46
Thanks for the reply, I couldn't find a link by myself. I managed to change each number one at a time to stac then back to pac.
I now have 3 codes 😀
on 13-05-2021 15:48
