Dermot57
Message 1 of 5
PIN help - Voicemail abroad
Hi. I am in Spain and cannot access my voicemail. It is asking for a PIN, which I don’t have. Tried calling 789 but can’t get through. Please advice, thanks.
Megan_L
  • 3.89K
  • 219
  • 390
Message 2 of 5
Re: PIN help - Voicemail abroad
Hi Dermot57,
Thanks for using the forums to get this issue with your mobile voicemail services looked into whilst you're in sunny Spain, I am sorry if this has been causing some frustration. I would be more than happy to look into this for you 🌞
I firstly have a link here which has helpful information in relation to your Voicemail PIN 👉 Virgin Mobile Voicemail
Please take a look and follow the information it provides, then let me know how you get on 🙂
If the information in the link doesn't help, I can try to assist within a PM, however as you're abroad at the moment any changes we make remotely are not guaranteed to work as you're not on the UK network at the moment.
Megan_L
Dermot57
Message 3 of 5
Hi Megan, thanks I did try that guidance you pointed to but I am not given the options described and it simply locks my access to the voicemail if I put in an incorrect PIN.
Megan_L
  • 3.89K
  • 219
  • 390
Message 4 of 5
Hi Dermot57,
Thanks for coming back to me after trying the tips in that link, I am sorry it didn't help in this instance!
I'll get a PM send over to you now 🙂
Speak soon!
Megan_L
Megan_L
  • 3.89K
  • 219
  • 390
Message 5 of 5
Hi Dermot57,
Thanks for chatting with me in our PM's, I am glad I managed to get this Voicemail issue sorted for you whilst you're outside of the UK 😁
I hope you have a lovely time.
Megan_L
