Squeaky
  • 86
Dialled in
PAC code for multiple numbers
Hi guys
I currently have 3 sims on my mobile account - 1 is a really old and long dead pay as you go sim, which needs removing but i don't know how, the main number is mine, and a third is for my wife.  I want to switch away from virgin for MY mobile, and I've already received a PAC, but when i look at the online account I can't see an option of getting a PAC or STAC for the second number!  I'm hesitant to switch away on my number only to discover hers gets shelved or there is no way for her to retain her number either elsewhere or with VM.
Any help appreciated
Tags (3)
enlli
  • 7.02K
  • 1.11K
  • 1.97K
Re: PAC code for multiple numbers
Can't PAC a dead PAYG so 1 is out
Your wife could do this from her phone. She may have to use your DOB if it is your account
  • Text ‘PAC’ and your date of birth (in DD/MM/YYYY format) to 65075 For example: PAC 01/03/1984
  • Text ‘STAC’ and your date of birth (in DD/MM/YYYY format) to 75075 For example: STAC 01/03/1984
