Tibbs3784
Nuisance phone calls
Can you stop daily nuisance phone calls from similar numbers. I keep blocking them and they then call back with a different but similar number. They are always 0208894____?
Any suggestions? Thanks
Tags (1)
paulchambers061
  • 2.38K
  • 259
  • 442
Problem sorter
Re: Nuisance phone calls
Try blocking 0208894*
Tibbs3784
Can I block a partial number?
enlli
  • 7.4K
  • 1.17K
  • 2.09K
Some phones let you use a wildcard (*), some don't.
