simon99lawrence
Not registered on
Trying to make calls and message saying not registered on network comes up. Have restarted phone and been into settings and network operators. Chose Virgin but message saying unable to register.signal strength looks fine.
Corey_C
  • 3.9K
  • 214
  • 323
Re: Not registered on
Thanks for your post and welcome to the Community Forums, simon99lawrence,
Sorry to hear that you are having mobile service issues. Are you able to try removing then re-adding the SIM to the phone or trying the SIM in another device?
You can also check out our online help guide for mobile: https://www.virginmedia.com/help/services-support/mobile
Let us know if you need further help?
Cheers,
Corey C
