Knightjill
Not registered on network samsung
Cannot make or receive calls , says Not Registered on Network
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Not registered on network samsung
Open the device settings.
Click the network then select forget network.
Reboot the device.
Go back into settings and reconnect.
  • 6.47K
  • 1.01K
  • 1.6K
Hi Knightjill,
Have you tried cleaning and then reinserting the sim card?
You don't say which samsung mobile the device is.  If it's a dual sim then try placing the sim card in the other sim slot.  If it's a very old mobile then it might not be supported.
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
