on 21-07-2021 22:27
I am in the USA with roaming turned on but no data (having burned through £100 in data as the phone wouldn't connect to the network).
I have checked for updates, restarted the phone, cleaned the sim card, tried to manually register (AT&T and Verizon are available but they stick on 'Registering on...' until I get 'Unable to register'). I am showing 4 bar signal strength but 'Not registered on network'. Please help! I am spending a fortune and have no telephone access.
on 22-07-2021 08:34
I'm afraid making a new post will not get a quicker answer and could confuse the issue.
on 22-07-2021 11:35
Hi Zitter,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issues you've had with your Mobile data.
I have been able to locate your account and do wish to help with this.
What I will do is private message you so we can confirm some account details firstly then go from there.
^Martin
