markmhayward
Not receiving calls
I transferred my number to virgin yesterday. I can make and receive texts and make outbound calls. But inbound calls do not connect. Any suggestions welcome!
Nathan_B
  • 5.04K
  • 170
  • 335
Re: Not receiving calls
Hi there @markmhayward, thanks for your post.
Sorry to see you are having issues with your inbound calls, just to confirm do you have an iPhone by any chance?
If so are you able to go to Settings>Phone>My Number, once there are you able to make sure the correct number is showing? If not can you please change this then give the phone a reboot. Once this is done can you test the phone to see if this has helped?
Nathan
markmhayward
Thanks Nathan
yes an iPhone 13 mini
I’ve tried to change the number but it doesn’t save the correct number. Have done a couple of resets but will try again.
Nathan_B
  • 5.04K
  • 170
  • 335
No worries, is the 'save' option in blue when you change the number or grey?
If this doesn't work it would be best to perform a network reset on the phone. This will just reset all the handset network settings and not a full factory reset.
Nathan
markmhayward
Thanks for the help Nathan. The network reset did the trick and my correct number is now showing.
Nathan_B
  • 5.04K
  • 170
  • 335
You are very welcome, glad to hear it has been sorted.
If you are ever in doubt for any issues in the future a network reset is always my go to.
Nathan
