Not receiving calls or texts
PeterT72
I've not been able to receive calls or texts for about a week (possibly since Sept 9th). Calls and texts out are OK and all data services. I've been through the whole of the troubleshooting procedure without success. My number has not been ported anywhere. I see from the forum that others report the same problem in the last few days but the resolution is not published. Can anyone advise? Thanks
12 REPLIES 12
Paul_DN
Hi Peter,
Thank you for reaching out to us in our community and welcome, sorry to see you are unable to receive calls and texts, is this happening with all calls and texts or just some people?
Paul.
Hi. Thanks for responding. The issue is happening with all calls and texts without exception including every test from other phones I've carried out plus those people that I know for sure have tried to contact me by either route.
Hi PeterT72
Thanks for coming back to us. Have you been able to try the SIM in a different handset? This is just to rule out the SIM being an issue.
Kind regards,
John_GS
Hello John_GS,
Thanks for the prompt response. Moving the SIM over is not something I've tried yet. I'll do that as soon as I can and get back to you
PeterT72
Cheers Peter, look forward to hearing back
Best,
John_GS
Hi John_GS & Forum Team,
I have tried the SIM in an older phone with exactly the same outcomes: calls and texts out are working but nothing incoming. I have one surprise to report, however, that may be instructive: at 04:39 I had a stream of 5 texts come through that had been sent over the past few days, all from a single contact. But since then, nothing.
Thanks and regards
Peter
Hello PeterT72,
Thank you very much for trying an alternative handset.
Id like to take a look into this for you and check the account etc.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
Hi Gareth,
I haven't seen any message appearing as yet. The issue persists. Is it still under investigation?
Many thanks
Peter
Hi @PeterT72,
I'm sorry to hear about this. I can see a private message was sent from Gareth, shortly after his main post yesterday - can you please try signing out, and back in and checking the purple envelope?
Cheers,
Reece - Forum Team
New around here? To find out more about the Community check out our FAQ
