Not enough credit on unlimited unlimited tariff
Kevp2518
I have an unlimited minutes and texts tariff set up for my stepson, and he has recently been getting the error message that he does not have enough credit to make calls.
All his calls that I have tried are to mobile numbers and get this error, everything else is working fine.
tested my other VMB mobile with his sister which is the same tariff and this works fine for calls.
1 REPLY 1
Gareth_L
Hello Kevp2518.
Thanks for your post.
Sorry to hear about the issue with your
I can look into this for you.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
