Not connecting to wifi
Our mobiles aren't connecting to wifi.  Says cant find IP Address.  When i try to connect manually it does for a moment then tells me it's trying to connect to an old IP address
My work PC is working fine through WiFi so not an internet connection problem
  • 4.69K
  • 678
  • 1.26K
Re: Not connecting to wifi
Try removing the WiFi profile from the phones and start from scratch
Thanks. Says failed to obtain IP address when i tried this
