antonysevans
  • 19
Message 1 of 31
Not Registered On Network
My wife and I each have a mobile. The signal in our apartment was never great, but we could use calls over WiFi ok. Then, around Nov 21 both phones kept constantly showing "refreshing sim data" or if I tried to phone "not registered on network". If I go outside and get a signal, then back into the apartment, WiFi calling works for a while but eventually drops out again.
The refreshing sim data completely drains our batteries every night. This still happens if I turn off WiFi, but not if I turn airplane mode on. I even changed my battery for a new one, but it still drains...
Tried all the suggestions I've seen, but no joy.
Travis_M
  • 4.59K
  • 169
  • 336
Message 2 of 31
Re: Not Registered On Network
Hi @antonysevans
Thanks for posting on our community forum!
Does this only occur when inside your apartment? How is your connection elsewhere?
Travis_M
antonysevans
  • 19
Message 3 of 31
Hi Travis,
It only happens in the apartment. I can get a bit of a signal on the landing, then disappears on the stairs. Everywhere else outside is fine. Something seemed to change with our local mast last Nov, so now it's like we are right on the edge of a signal, but it varies continuously.
I was happy when the signal was bad, but wifi calling worked. But now we keep losing connection to the network, so WiFi calling stops.
It's a real pain because I am a carer for my wife, so have lots of calls to medical etc. I have to go outside to make sure I haven't missed a call back.
Tony
Travis_M
  • 4.59K
  • 169
  • 336
Message 4 of 31
Hi @antonysevans
Sorry to hear about this
Which SIM have you got at the minute, is it EE, Vodafone or ourselves?
Travis_M
antonysevans
  • 19
Message 5 of 31
We both have a Virgin sim
Travis_M
  • 4.59K
  • 169
  • 336
Message 6 of 31
Hi @antonysevans
Thanks for the reply
Can you check here please? This will show us an issues with any masts / the network, please keep us updated.
Travis_M
antonysevans
  • 19
Message 7 of 31
The O2 status checker shows:
CF64 5QH
Our Network can get busy in this area.
This means your data could be slower than normal. We’re sorry about that. Our team is aware and working to make it better. Our top tips for staying connected would be to find local Wifi hotspots and download whatever content you need whilst connected to Wifi, so you can still enjoy it on the move.
Updated 09:36 (refreshed hourly). Recent faults might not show yet.
Expected coverage for this area
Good indoors and outdoors.
Good indoors and outdoors. Good for mobile broadband.
Good indoors and outdoors. Good for 4G calling.
Sorry. We do not have 5G coverage at this location.
Travis_M
  • 4.59K
  • 169
  • 336
Message 8 of 31
Hi @antonysevans
Thanks for the reply!
Unfortunately the case is as above, the team are looking to improve the network in the area - this isn't an issue we can fix on an individual basis.
I do apologise for the inconvenience
Travis_M
antonysevans
  • 19
Message 9 of 31
Hi Travis,
But why doesn't WiFi calling work when there is no signal?
David_Bn
  • 9.4K
  • 392
  • 715
Message 10 of 31
Thanks for coming back to us @antonysevans, can you possibly advise what handsets both you and your wife are using?
Kindest regards,
David_Bn
