wickham1962
Settling in
No virgin mobile signal at home
I've had no virgin mobile signal in my home since the 16th Dec 2020. If I travel a mile away from my home it works fine. The fault is due to a problem with the local EE transmitter I have been told. I am unable to make or receive calls or messages. I have complained numerous times about this and all I get is my bill is reduced for my 2 accounts. Not being able to use the mobile has resulted in an increase in my landline usage and a bigger bill through no fault of my own. Really dont know what to do for the best. Stressed and frustrated
enlli
  • 6.52K
  • 1.04K
  • 1.8K
Re: No virgin mobile signal at home
You can check the status of your local transmitter by putting in your postcode and selecting the button for having a problem
https://coverage.ee.co.uk/coverage/ee
Chris_W1
  • 3.6K
  • 160
  • 204
HI wickham1962, thanks for the message and sorry to hear that you are having issues with the service, the signal cannot be guaranteed in the home due to interference. Please see the following Ofcom link here and it will show what signal you should be getting. ^Chris
