on 04-01-2023 18:33
I'm constantly having issues with no signal on one of my sims on my family plan. I can't send or receive text or have any data it just says emergency calls only.
I've double checked and the account has unlimited text and call, has plenty of data and is within it's spending cap.
Any idea what is going wrong?
Thank you
on 04-01-2023 18:58
Hi damian_burrin, thanks for the message.
Would you be able to remove the sim and insert it.
Then go to the settings menu and do a network search.
Pease let us know how it goes?
Kind regards, Chris.
on 04-01-2023 19:06
yeah I have which fixes it but then a few days/hours later it does the same
on 04-01-2023 19:09
Hi @damian_burrin thanks for your reply, that is strange I do apologise.
Can you please advise if this happens when you place the SIM in an alternative device?
Many thanks
on 04-01-2023 19:13
I've put the sim in an old phone and it seems to work. The phone isn't old its a MI 10 LITE
I'm not sure really what to do.
Damian
on 04-01-2023 19:46
Hi Damian, thanks for your reply.
Does it have a dual SIM slot your phone, if so can you try the SIM in another slot perhaps?
Also this can help: Press Settings.
Press SIM cards & mobile networks.Press the required SIM.Press the indicator next to "Turn on" to turn use of the SIM on or off.If you turn off use of the SIM, press OK. ... Press the Return key. Press the required setting below "Default for calls".
Many thanks
