LAB1
No signal
I've just turned on my very infrequently used Nokia 105 and there is no signal, Emergency calls only. Any ideas please
enlli
  • 9.52K
  • 1.43K
  • 2.74K
Re: No signal
Is it PAYG? Have you made a chargeable call or sent a text recently? If not it may have been disconnected for none use.
Also possible is it has been switched off with this months closure of PAYG
LAB1
Re: No signal
Yes PAYG, no call or text recently, has PAYG finished ? I'm sure I had a balance
enlli
  • 9.52K
  • 1.43K
  • 2.74K
Re: No signal
Is in the process of finishing, about a week to run. You were probably sent text messages but if the phone was not switched on they may well of expired.
Normally if a PAYG is shut down for none use there is no refund of balances. However, with the closure some balances are being refunded.
Hopefully one of the team here will be able to advise.
LAB1
Re: No signal
Thanks for your help, I'll wait to see if one of the team reply
John_GS
  • 14.42K
  • 737
  • 1.34K
Re: No signal
Hi LAB1
Thanks for posting and thanks to all the community that have replied.
I will send a PM to see if there's anything we can do and advise further.
Best,
John_GS
