No signal abroad
Trying to use my mobile in Spain. Roaming switched on and international call bars switched off but no signal.
Similar experience in Germany last month. Virgin checked the above had been set correctly. Can one use wi-fi abroad at present.
Very frustrating so any help would be gratefully received.
Cheers
  • 3.34K
  • 603
  • 859
Re: No signal abroad
Hello
Thank for joining in on the forum, we will try the best to get your issue resolved.
You can try the following if you have the newer (last 2 years) purple sim card, you can try the sim tool to get it working,
How to access the sim toolkit.
For Android:
Select Apps from the Home Screen
Select Virgin SIM Toolkit Icon
Select Roaming
Select Select Mode
Select Manual
Select International-you are done, go back to Home Screen
To Switch back when in the UK:
Select Apps from Home screen
Select Roaming
Select Select Mode
Select Automatic and go back to Home Screen
For iOS:
Select Settings from the Home Screen
Select Phone Icon
Select SIM Applications
Select Roaming
Select Select mode
Select Manual
Select International and you are done, go back Home screen to retry
To change back when returning to the UK:
Select Phone Icon
Select Roaming
Select Select mode
Select Automatic mode - you are done, go back to Home screen
**It is important that you set the SIM roaming applet back to Automatic mode once in the UK or you will not be able to access service when you return.**
Regards Mike
My sim card is the older version so may need to review when home
Thanks for your help
Cheers
