Message 1 of 9
No phone signal in own home
I live in Erdington and can’t even get phone signal in my own house. Missing lots of phone calls and can’t send texts. My Mrs couldn’t even be informed about the birth of her brothers child because of it for hours. Is this common and what can be done???
  • 119
  • 14
Up to speed
Message 2 of 9
Re: No phone signal in own home
Are you seeing no service??
It's normally good network Brum.
  • 3.88K
  • 528
  • 1.04K
Message 3 of 9
Is this recent or an ongoing problem?
If recent then check here for network problems https://myaccount.ee.co.uk/networkchecker/checkservice
Click to learn more about VIP
Use Kudos to say thanks
Message 4 of 9
Ever since I have been on virgin for maybe 2 weeks
  • 119
  • 14
Up to speed
Message 5 of 9
I've checked with mates living that side of Brum EE have a issue in the area which will explain the situation.
Click the link above and it will say when it should be fixed.
  • 3.88K
  • 528
  • 1.04K
Message 6 of 9
Right. You may be in an unfortunate position. The OFCOM coverage map may give you a better indication of signal. Use EE. However there is a slight difference between EE and Virgin as the later does not have access to 800Mhz which works better indoors.
https://checker.ofcom.org.uk/
Message 7 of 9
Normally 1 bar but then cuts out and is all distorted during call attempts. And people can’t even phone us and we are unaware they have tried till they tell us the next day in person.
  • 119
  • 14
Up to speed
Message 8 of 9
EE have issues that area of Birmingham which more than likely the issue.
  • 2.54K
  • 207
  • 439
Problem sorter
Message 9 of 9
I see other posters have commented on some problems that EE may be having in your part of the world, I'd hope this is the case and all is resolved soon. How long have you had your Virgin Mobile for, I'd just be concerned if you've only just taken this out and can't sensibly use your 14day return policy on the off-chance this ends up being a long-term problem.
