Dixon200402
Message 1 of 11
No phone signal, dips in and mostly out…
Phone signal lately is non existent...I sometimes get 2 bars if lucky, I have none at present… again. I have been on the phone for hours to virgin with no outcome.. help as I’m actually thinking of leaving after 8 years…
enlli
  • 9.52K
  • 1.43K
  • 2.74K
Message 2 of 11
Re: No phone signal, dips in and mostly out…
Is this in one place? If so I guess we are looking at a network fault or you have been moved off EE signal onto Vodafone and their signal is weaker.
Dixon200402
Message 3 of 11
Mostly at home and work but never had anymore than 2 bars for about 5-6 months…
Akua_A
  • 4.12K
  • 107
  • 286
Message 4 of 11
Hi @Dixon200402
Welcome to our community forums and sorry to hear you have been having issues with your phone signal. We can understand this is not ideal and we want to best help.
Was the advice given by @enlli useful? Do you need any further help?
Akua_A
enlli
  • 9.52K
  • 1.43K
  • 2.74K
Message 5 of 11
Is it possible to do a manual network search and let me know what networks are visable?
swazer161
  • 15
Message 6 of 11
I had the same problem with my and wife's phone. Didn't get any real answers so moved to plusnet, better deal, took 2 days. It's on the ee network and both our phones went to full signal when I put new sims in.
Dixon200402
Message 7 of 11
I’ve got virgin, EE, 3 uk and 02 uk
Akua_A
  • 4.12K
  • 107
  • 286
Message 8 of 11
Thank you for letting us know @Dixon200402
Please try the following link and let us know if you need any further help https://www.virginmedia.com/help/mobile/virgin-mobile-issues.
Akua_A
enlli
  • 9.52K
  • 1.43K
  • 2.74K
Message 9 of 11
Thanks for that. Shows to me you have been moved onto the Vodafone network.
Their coverage checker is here. Will also say if there are faults. (Although coverage checkers are often optimistic)
https://www.vodafone.co.uk/network/status-checker
Ali_G
Message 10 of 11
I'm at the west side of Edinburgh and have just yesterday called 789 about the same problem.  Incoming callers are told my phone is unavailable or if connection aquired it breaks up repeatedly or drops out altogether.  I have to be upstairs near a window to get anything on my signal meter.
I was informed that the move to Vodafone had taken place on 15th December 21 and this was likely the cause.  She would reset my account at her end and I was asked to switch between 5G & 4G. When pointed out it was not a 5G phone or sim this seemed to cause confusion.  Eventually asked to reset my connection after finishing the call and wait 24 hours to see if the signal improved if not it was likely that the Vodafone signal was not strong enough in my location and I should switch to a provider that could give me mobile cover in my location but in the meantime she would put in a report to the Tech people.
Not a very good customer service outcome.  Needless to say rebooting my phone after the call ended did nothing to improve my signal.  unless anyone else can suggest any other fixes then it looks like I will need to leave Virgin Mobile after very many years and bring most of my family and many friends to Virgin.
