No network connection
Dennisdog2176
I have just returned from abroad and now I don't have any network connection . I can't send any messages receive or make  calls either. And can't find any settings that I have changed or can change.  My phone didn't work abroad anyway so can only use wifi
6 REPLIES 6
Chris_W1
Hi Dennisdog2176, thanks for the message.
I am sorry to hear that you are having issues with the network connection.
Would you be able to switch of the roaming in settings and perform a manual network search please?
Kind regards, Chris.
Samsung s21. Tried that and no difference.  Tries removing sim and putting back. Tried resetting whole phone. Nothing seems to change
Hi Dennisdog2176, thanks for the reply.
I will send you a private message so that this can be looked into.
Ho Chris.  I didn't receive any message as that is the problem. I have no network connection.  I can only use my phone through home wifi
enlli
The message will come through the forum. Click on the purple envelope at the top
Hi Dennisdog2176, thanks for the reply. I have responded to your private message. - Chris
