mm011
No mobile signal at home
Hello,
I signed a one year mobile contract in early July and moved home afterwards (after 14 days cooling period). I found the Virgin mobile indoor signal in my new home is very poor, almost no signal at all. I put both Virgin mobile and Vodaphone SIMS in my mobile and there is big difference between them. Vodaphone's signal is perfect with 3 or 4 bars, while Virgin media has no service.
This is clearly not the quality of service I subscribed for because I cannot use mobile phone at home. The issue has existed for a while. I was considering a formal complaint and bring it to CISAS, but before that, could a staff member here help resolve it quickly for me please? Thanks in advance.
paulchambers061
  • 2.38K
  • 259
  • 442
Problem sorter
Re: No mobile signal at home
A quick check you can do, maybe you are in a signal not spot
https://checker.ofcom.org.uk/mobile-coverage
Check indoor 4g and not 4g for the EE signal
As virgin use 3g and 2g for calls the not 4g is important for that.
mm011
Thank  you very much for your useful link. It seems the signal is bad in my area. Please tell me what shall I do with it. Thank you.
