No mobile connection in France
kevinsimpson
No connection after landing in France. Three months previously everything worked fine on a previous trip.
no issues around mobile coverage- everyone around me has a signal.
have mobile data switched on. Roaming switched on.
when I switch airplane mode on and off the phone searches for a network and then says no service.
i can’t even phone over wifi, although that is enabled!
connected now through hotel wifi
1 ACCEPTED SOLUTION
Accepted Solutions
Thanks Kevinsimpson,
Can you please see if this helps, just go to.
Settings > Phone > SIM Applications > Roaming > Mode > Manual > International.
If you’re using a newer iOS, then you it will be under Mobile Data instead of phone.
Once this has been done you might need to reboot.
Gareth_L
6 REPLIES 6
Gareth_L
Hello kevinsimpson.
Sorry to hear the roaming is not working as it has previously.
Can I please ask what handset it is that you have?
Gareth_L
  • iPhone x
My device is an iPhone XR
Gareth_L
Thanks Gareth
that has solved the issue. And relax… Thanks again
Kevin
Hey Kevin.
très bien
Glad to hear its all good now.
Enjoy your time over the water.
Gareth_L
