Wawaw
  • 5
Message 1 of 5
No incoming calls or text since number porting
I’ve been advised that my number port is due today and it appears to have gone through and is working ok on outgoing calls but I am unable to receive any calls or texts.  Please help!!!
DJ_Shadow1966
  • 7.13K
  • 1.36K
  • 2.02K
Message 2 of 5
Re: No incoming calls or text since number porting
Hello
Have you received the text message saying that the port has been completed ?
Regards Mike
Wawaw
  • 5
Message 3 of 5
No not yet. Wasn’t too sure what happens and whether I would be notified on completion. Am I just a bit too eager???🥴
DJ_Shadow1966
  • 7.13K
  • 1.36K
  • 2.02K
Message 4 of 5
Hello
Yes you will get a notification once the port has been completed, I have found and seen here that normally the outgoing is the first to go over, I would hang on until you receive the notification.
Regards Mike
Wawaw
  • 5
Message 5 of 5
Thanks Mike.
I will give it more time and await the message before trying to speak to customer service. 🙏🏻
