NikkiJD70
  • 7
Message 1 of 10
No Signal
I am having trouble getting someone to understand my problem.
I have no mobile signal and can only make calls through the WiFi. I was told I needed a new SIM. I have received this but it hasn’t changed anything.
The last adviser said I can see you have made calls and data so there’s no problem.
Yes there is, I can only make calls using WiFi and I don’t have a problem with Data.
How can this be fixed.
enlli
  • 7.36K
  • 1.17K
  • 2.08K
Message 2 of 10
Re: No Signal
Is this in just one place or wherever you are?
NikkiJD70
  • 7
Message 3 of 10
Re: No Signal
Wherever I am.
I can’t even text them.
enlli
  • 7.36K
  • 1.17K
  • 2.08K
Message 4 of 10
Re: No Signal
Interesting that your top bar is not even showing the symbol for no network
Have you been into your connection settings ... networks and done a manual scan?
NikkiJD70
  • 7
Message 5 of 10
Re: No Signal
Thanks for your reply, normally there was a bar chart and it goes up in strength but it’s just 4 dots.
sorry I’m a bit not good will tech, were would  I find this in settings.
Thanks for your time in helping me.
enlli
  • 7.36K
  • 1.17K
  • 2.08K
Message 6 of 10
Re: No Signal
Usually in Settings / Connections / Mobile Networks / Network Operators. Let it search then manually select Virgin
NikkiJD70
  • 7
Message 7 of 10
Re: No Signal
I’m so sorry to keep bothering you. I’ve set it to Virgin and still nothing.
I can’t even call them.
Feeling very frustrated
enlli
  • 7.36K
  • 1.17K
  • 2.08K
Message 8 of 10
Re: No Signal
I only know one more thing after that I'm stuck
Select Apps from Home screen
Select Virgin SIM Toolkit Icon
Select Roaming
Select Select Mode
Select National and go back to Home Screen
enlli
  • 7.36K
  • 1.17K
  • 2.08K
Message 9 of 10
Re: No Signal
Check the APN settings that they match these and not saying something like  Bell or Proximus
https://community.virginmedia.com/t5/Virgin-Mobile/New-Purple-Virgin-Mobile-SIM-and-need-the-APN-set...
NikkiJD70
  • 7
Message 10 of 10
Re: No Signal
Thank you so much for your time and help.
I followed your advice and it appears to be working now.
Nobody form Virgin replied so I am forever grateful
Nikki
