  • 5
No 4G data APN settings are correct
Recently received an updated replacement sim card, which installed OK, but cannot get any 4G data connections anywhere, only H or H+. Phone is set for 4G preferred and tha APN settings are checked as correct. Another phone in same location, but on EE gets 4G no problem.
  • 4.72K
  • 685
  • 1.27K
Re: No 4G data APN settings are correct
Answered in other thread.
  • 5
According to the Virgin service checker my post code area should have excellent 4G and 3G connectivity, but I get neither
  • 5
 Wherever I am the phone will not register to the Virgin 4G service, even though it is often the strongest signal avaliable.
  • 3.09K
  • 143
  • 244
Good Afternoon RichardMPerry
Are you able to get 4G coverage since your post?
If you're still struggling, are you able to advise me what APN settings you've added to your handset?
If you're happy to share you're full postcode with me I will be able to look into the masts in your local area to see if there is an issue in the local area that's preventing you from using the data services
Kindest regards,
David_Bn
  • 789
  • 121
  • 151
Well-informed
If your Sim Card is not inserted or is not seated properly, it may cause your phone to only allow calls to 911. Ensure your Sim Card is securely inserted into the slot. It may not hurt to remove it and re-seat it.
Looking at the screenshot, the phone is set for Emergency Calls only, instead of a  network provider.
Try doing a manual network search and select any network other than Virgin or EE It will fail
Perform another manual network search and select Virgin. You should then be connected to the network
Dave
