Sarahj7
Network Issue Coventry
I live in CV2 and for 2 weeks I have been unable to make or receive calls. I called last week and they sent me a new sim which hasn't helped. I have now been told there's a problem with a mast in Courthouse Green. How do I go about getting a refund and also find out when this issue will be resolved.
enlli
  • 8K
  • 1.25K
  • 2.28K
Re: Network Issue Coventry
As fir the signal that is down to EE. Best to check
 https://myaccount.ee.co.uk/networkchecker/checkservice
If EE are aware the only thing you can do is register on that site for updates
Compensation is usually only considered one a fix is in place and the total number of days worked out.
