Nokia215
Message 1 of 5
Need help to unlock my Nokia 215
Hello, Can someone please help me to unlock my Nokia 215.
I bought the phone from Argos about 3 years ago and the SIM has since expired with £10 credit on it.
So I don't have a working SIM and I am unable to speak with anyone when calling the Virgin help team.
I want to unlock the phone to use a SIM from another network.
Thank you
David_Bn
  • 4.91K
  • 226
  • 402
Message 2 of 5
Re: Need help to unlock my Nokia 215
Good Morning Nokia215,
Thanks for your post and a very warm welcome to you!
Sorry to see you've been having issues with the unlocking of your handset.
Can you tell me if you've been able to speak to our team since your post in regards to this issue?
If you still seek assistance, do please drop a response and we'll seek to assist you further
Kindest regards,
David_Bn
Nokia215
Message 3 of 5
Hello David,
  I have spoken to someone in the team.
They gave me an unlock code, however, the code requires a SIM, which I don't have, in order to use the code.
My original SIM was de-activated (wasn't used for a long time because the phone was a back up and not used).
Do I just need to get any SIM to unlock the phone with the code?
Thank you
DJ_Shadow1966
  • 6.86K
  • 1.31K
  • 1.9K
Message 4 of 5
Hello
If the PAYG sim has not been used for more than 90 days then I am afraid that both the phone number and the credit are lost, the other issue I am afraid that VM no longer sell PAYG sims.
Any SIM when placed in the phone will ask for the unlock code you will then be able too make the phone unlocked for any network.
Regards Mike
enlli
  • 7.03K
  • 1.11K
  • 1.97K
Message 5 of 5
1. Turn on the phone without any sim card
2. Enter the following sequence (#pw+unlock code+7#) on your NOKIA 215 just like a phone number*
* Characters p, w, + will appear after pressing the *(star) symbol a couple of times
4. Press # at the end to confirm the code
5. Message "SIM restriction OFF" should appear.
Your Nokia 215 is now unlocked !!!
