skiboysteve
Message 1 of 5
My virgin phone won't connect to landline numbers
Just recently my iPhone 6 on the Virgin network has stopped connecting to landlines. When the number is dialled it seems to connect for a split second then turns to an engaged tone. Other numbers get a french message. The called number doesn't get the call at all. I have stopped the wifi calling option and mobile numbers are not affected. Any ideas??
Chris_W1
  • 4.06K
  • 185
  • 255
Message 2 of 5
Re: My virgin phone won't connect to landline numbers
Can you confirm if this is happening on one or more than one wifi networks, does a network search change anything? Chris
skiboysteve
Message 3 of 5
I'm not using WiFi calling and have switched it off as I thought it may be the problem. So it is when using the virgin mobile network. I have started changing stored numbers to +44 instead of just using 0 and it has helped with some numbers but when ringing my home landline even with +44 it still won't connect. Got my wife to phone the home landline with her iPhone 7 and it connects straight away so not a problem with landline.
enlli
  • 7.36K
  • 1.16K
  • 2.08K
Message 4 of 5
This is worth a try
to:
Settings -> mobile data -> SIM Applications -> tap "Roaming"  -> tap "Select Mode"
I found "automatic" was selected by default.
Tap manual -> then choose National.
Now make sure your numbers are set to the correct format. If not change region to anything other than UK (Settings -> General -> Language and Region -> Region) and then change back to UK
skiboysteve
Message 5 of 5
Enlli. Thanks for that advice. I have changed the settings as you suggested and it seems to have worked!! I live on the South Coast and may have been picking up signal from Europe. Who knows, but this seems to have solved the problem. Many thanks.
