argiel
  • 42
  • 11
Dialled in
Message 11 of 21
Re: My phone keeps thinking it is in Belgium!
I have exactly the same problem: iPhone SE keeps acting as if it’s in Belgium. Changing location works temporarily then reverts to Belgium.
This prevents people from recognising who my texts are from and also results in calls I make to UK numbers trying to connect to Belgian numbers with the +32 prefix.
I *think* it only happens when I am out, not at home using WiFi.
From the discussion it looks like:
1 I’m not the only person with this problem
2 There isn’t a confirmed working solution, only a few suggestions which haven’t worked.
enlli
  • 9.63K
  • 1.44K
  • 2.77K
Message 12 of 21
So I assume you have tried this: it seems to have worked for many.
The problem is caused by the nature of Virgin SIM cards which are Belgian in origin to allow Virgin to change network providers and give them access to roaming. iPhones don't seem to handle that well.
This problem has been round since the cards were introduced in 2016
If this does not work then I'm afraid you are out of luck
Settings -> mobile data -> SIM Applications (near bottom) -> tap "Roaming"  -> tap "Select Mode"
I found "automatic" was selected by default.
Tap manual -> then choose National.
Now make sure your numbers are set to the correct format. If not change region to anything other than UK (Settings -> General -> Language and Region -> Region) and then change back to UK region
argiel
  • 42
  • 11
Dialled in
Message 13 of 21
I did see that approach suggested but it was followed by JulianFr reporting that it worked only temporarily and caused other problems, so you’ll appreciate why I don’t feel confident that it’s sound solution.
enlli
  • 9.63K
  • 1.44K
  • 2.77K
Message 14 of 21
Well it's worked for lots of people. You can always change back to the original settings
Only other solution is to move from Virgin. I think four and a half years with no fix will tell you it will never be sorted
argiel
  • 42
  • 11
Dialled in
Message 15 of 21
Well here’s hoping it works for me too!
I’m new to Virgin, and disappointed that they  are offering this service with a known issue. I was going to switch my wife’s contract too but I’m glad I was cautious and just moved mine first!
Thanks for your help.
Zach_R
  • 4.4K
  • 145
  • 309
Message 16 of 21
Hi @argiel,
Thank you for your posts. We're here to help.
I'm very sorry to hear you're having some issues with your mobile service lately. Have you followed the steps suggested by @enlli to see if they help yet?
Zach - Forum Team
argiel
  • 42
  • 11
Dialled in
Message 17 of 21
It seems to be working so far, thanks.
Zach_R
  • 4.4K
  • 145
  • 309
Message 18 of 21
Hi @argiel,
Thank you for the update. Glad to hear that this issue appears to now be resolved.
You know where we are if you need any further assistance.
Zach - Forum Team
Mike4915
Message 19 of 21
Hi, I’ve just started having the same problem on my iPhone XS. Did this fix work for you?
Corey_C
  • 5.36K
  • 259
  • 456
Moderator
Moderator
Message 20 of 21
It should also work for you , Mike4915
