Muddtastic70
  • 5
Message 1 of 13
My calls to landlines are showing up as international .
In the past couple of month my calls from my mobile have started showing up as international on the landlines!!! Its causing a problem as people aren’t keen to answer and think it’s a marketing call , has anyone come across this and got a solution ?
Paul_DN
  • 5.8K
  • 341
  • 613
Message 2 of 13
Re: My calls to landlines are showing up as international .
Hi Muddtastic70,
Thank you for reaching out to us in our community and welcome, I am sorry to hear when you are calling landlines on your Mobile it is showing up as overseas.
Can I ask what Mobile phone you have, is it a iPhone?
Paul.
Muddtastic70
  • 5
Message 3 of 13
Yes it’s an iPhone X
Paul_DN
  • 5.8K
  • 341
  • 613
Message 4 of 13
Hi Muddtastic70,
Thanks for confirming this, can you go into settings, phone, dial assist and turn it off, once done see if you can call someone and see if it still happens?
Paul.
Muddtastic70
  • 5
Message 5 of 13
Thank you for the suggestion  I’ve just tried it and it didn’t work I’m afraid
enlli
  • 7.01K
  • 1.11K
  • 1.97K
Message 6 of 13
Try this
Go to:
Settings -> mobile data -> SIM Applications -> tap "Roaming"  -> tap "Select Mode"
I found "automatic" was selected by default.
Tap manual -> then choose National.
Restart the phone for it to take effect
Muddtastic70
  • 5
Message 7 of 13
Hi there thank you so much for trying to help but that hasn’t changed it
ashpole
  • 148
  • 18
Up to speed
Message 8 of 13
I managed to fix my woes, I moved carriers and ported out my number after just 77 days with VM. The small exit fee I paid was the best value I’ve had in months.
Travis_M
  • 368
  • 21
  • 38
Message 9 of 13
Hi @Muddtastic70
Thanks for posting on the community forum!
Could you try the SIM in a different phone for me and see if this changes anything?
Travis_M
enlli
  • 7.01K
  • 1.11K
  • 1.97K
Message 10 of 13
Probably won't happen if you use an Android, fault appears confined to iPhones.
