Bethanyg
My calls and texts are not working
I ported my number from Eir to virgin and since then I haven’t been able make or receive calls or texts
enlli
  • 9.81K
  • 1.45K
  • 2.82K
Re: My calls and texts are not working
This forum is UK based. Virgin Media Ireland is a totally different company. You will need to contact them
https://www.virginmedia.ie
sjp123
  • 2.45K
  • 150
  • 346
Problem sorter
If Eir is an ROI carrier, you have the wrong Virgin Mobile.
If so, try virginmedia.ie
