daveoc
  • 178
  • 22
Up to speed
Moved From Oomph/Virgin Mobile To Volt/O2
Negotiated a new contract and as a result I am now on the Volt/O2 package rather than the Oomph/Virgin Mobile that I've been on for the last 16 months.
My question is, how do I close/remove the Virgin mobile account. Can't seem to find a way to delete/close the account.
Gareth_L
  • 10.75K
  • 600
  • 1.19K
Re: Moved From Oomph/Virgin Mobile To Volt/O2
Hi daveoc
I can take a look at this for you
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
