Breckon98
Mobile signal
When people ring  my mobile it just does one continuous beep instead of ringing like normal. & I’ve also tried to watch bbc I player but says it’s not available in my location. I think my signal/location isn’t correct?
Tags (3)
DavidJWalker
  • 716
  • 52
  • 109
Rising star
Re: Mobile signal
signal does not go off location thats gps in the phone bbc iplayer only works off gps on a moblie
beeping is not a ringing in the uk
My Broadband Ping - Virgin Media 350MB
Using Ultimate Oomph bundle
Just another VM user trying to help out so my answers may be wrong. If you do like my answer please mark it as helpful; it may help others
enlli
  • 7.4K
  • 1.17K
  • 2.08K
Re: Mobile signal
iPhone?
Breckon98
Re: Mobile signal
I am in the uk. And my phone beeps when people ring which isn’t normal.  And my gps must not be working properly
Breckon98
Re: Mobile signal
Yes I phone xs max
enlli
  • 7.4K
  • 1.17K
  • 2.08K
Re: Mobile signal
Virgin use Belgian SIM cards and phone thinks it is in Belgium
Try This
Settings -> mobile data -> SIM Applications (near bottom) -> tap "Roaming"  -> tap "Select Mode"
I found "automatic" was selected by default.
Tap manual -> then choose National.
Now make sure your numbers are set to the correct format. If not change region to anything other than UK (Settings -> General -> Language and Region -> Region) and then change back to UK region.
