Mobile signal
Why can’t I get a mobile signal in the Channel Islands again ??????
  • 3.88K
  • 528
  • 1.04K
Re: Mobile signal
Not sure if your SIM was issued in the last 18 months. If it was
try this workaround, posted by vm moderators recently.
**It is critical that you set the SIM roaming applet back to Automatic mode once in the UK or you will not be able to access service when you return.**
For Android:
Select Apps from the Home Screen
Select Virgin SIM Toolkit Icon
Select Roaming
Select Select Mode
Select Manual
Select International-you are done, go back to Home Screen
To Switch back when in the UK:
Select Apps from Home screen
Select Roaming
Select Select Mode
Select Automatic and go back to Home Screen
For iOS:
Select Settings from the Home Screen
Select Phone Icon
Select SIM Applications
Select Roaming
Select Select mode
Select Manual
Select International and you are done, go back Home screen to retry
To change back when returning to the UK:
Select Phone Icon
Select Roaming
Select Select mode
Select Automatic mode - you are done, go back to Home screen
Remember you will be charged for roaming
Click to learn more about VIP
Use Kudos to say thanks
