Bads18
Mobile signal power Ruislip
I have 4 mobile SIM accounts with Virgin for the past 3 years or so the last month I cannot get a phone signal inside my house.  Rung virgin 4 times been told various excuses but nothing ever sorted. The last call said I should change provider. I want to stay but will have to leave if it's not sorted. Has anyone else had the same problems with signal strength in the Ruislip area?
Tags (1)
enlli
  • 8.01K
  • 1.25K
  • 2.28K
Re: Mobile signal power Ruislip
If it is down to signal then there is little Virgin can do being an MVNO running off EE. You can check direct with EE.
I know both EE and Vodafone have been doing work on their networks in preparation for future changes. No doubt the others too.
https://coverage.ee.co.uk/coverage/ee
