13-12-2021 13:58 - edited 13-12-2021 13:58
Problem with our Virgin Mobile signal here at home - began around a week ago when my signal on Android went from full strength down to one bar, very occasionally two. My wife's iPhone went from full strength to no signal at all. Out & about - both fine, strong signal. We picked VM specifically because their network worked well here at home, unlike others eg. O2, which needed a BoostBox when I was on their service with work. Called CS, but of course all they can say is that our postcode is showing a good service. Something has definitely changed, but how to find out what??
It's rendered my wife's phone unusable and mine not far behind. I'd hate to move networks as we've been with VM for years, but it's looking like a switch to EE which we know works well here.
on 13-12-2021 14:25
Do you know if you have both been moved off EE and onto Vodafone?
The other scenario is you are still on EE and there is a network fault but CS are looking at Vodafone!
on 13-12-2021 14:27
Hi springer64
Thanks for posting. Sorry to hear of the signal issues. I'd like to help further so I'll go ahead and send you a PM now.
Best,
on 13-12-2021 14:32
Thanks, but how would we know if we've been moved?
on 13-12-2021 14:57
@springer64 wrote:Thanks, but how would we know if we've been moved?
If you do a manual network search Vodafone will be missing (Replaced by Virgin) and EE will be visable
on 13-12-2021 15:28
No, still got Virgin & Vodafone showing. No EE.
on 13-12-2021 15:36
OK then try here
https://coverage.ee.co.uk/coverage/ee
Put in your post code and a phone type and use the Check Status button
on 13-12-2021 15:48
Sorry, I'm confused now. That just tells me that there's a strong EE network signal here, which I knew anyway. Doesn't explain why our two phones on VM have lost signal.
on 13-12-2021 15:57
Did you press Check Status That tells you if there is presently a problem or not.
on 14-12-2021 17:25
My wife and my own phones signals have completely dropped out in the last couple of days.
