rogernhare
Just joined
Mobile phone Samsung S7edge
My phone has completely gone dead. I have tried all the usual options to try to get it started but there is no response at all . I have checked the charger which is ok, Is this likely to be a battery issue?
DJ_Shadow1966
  • 7.13K
  • 1.36K
  • 2.02K
Re: Mobile phone Samsung S7edge
Hello
When you plug in the charger cable do you get anything coming up on the screen ?
Have you tried a different charger cable as these can do bad ?
Can you try to enter recover mode
1) Press and hold the Volume Up + Home + Power Button Until you see the Samsung Logo.
If non off the above work then it could be the battery how long have you had the phone.
Regards Mike
