on 03-10-2021 14:41
Changed to VM earlier this year, no issues. Last Saturday when calling my mum was told “you are dialling an incorrect number” I’m not. Also the calls I’ve tried to make to my mum have her number listed as +34 and Belgium. She lives in England. This is a known error, what is the solution? Tried reading threads but they are full of ppl with the same issue or then DMing so I can’t see resolution.
on 03-10-2021 14:54
You will have to apply this
Also make sure that dial assist is off
There is no other 'fix' or likely to be
on 03-10-2021 15:31
Hi @Jj_mobile,
I am very sorry to hear that you're having these issues with your mobile handset. Have you followed the advice provided by @enlli yet to see if that helps at all?
