  • 9
Mobile data not working
Ok, loads of data available, WiFi all working.
Out of WiFi range, turn on to data and I get no connections ('no data connection'). Only able to access data / internet through WiFi.
I'm on a basic contract with Virgin (is that the reason?) but it still gives me 1GB of data, which I've been told still gives me ability to connect away from WiFi.
  • 4.77K
  • 694
  • 1.28K
Re: Mobile data not working
You will first need to check you have the correct APN settings installed on your phone.
They are listed in a sticky at the top of this group
  • 9
Hi, Sorry, you're dealing with a philistine here. Which sticky? Where on the page do I look?
  • 4.77K
  • 694
  • 1.28K
https://community.virginmedia.com/t5/Virgin-Mobile/New-Purple-Virgin-Mobile-SIM-and-need-the-APN-set...
These are for Andriod but the will be similar on an iPhone
Not sure what phone you have but usually a Google search on the model and how to set the APN comes up trumps
