williebhoy61
  • 21
Message 1 of 5
Mobile data issues
Hi everyone  i am having issues with my mobile data when i am trying to acsess my online betting accounts , The betting account apps work perfect using my home wifi but if i am not in the house and try to use the apps when i am using my mobile data . the apps are failing to open and i keep getting the failed to connect message , I  have tried all of the troubleshooting guides etc but still no joy , when i put my old BT sim card back into my phone the apps work  . is there anything i need to do to fix this issue
Alex_RM
  • 4.53K
  • 260
  • 344
Message 2 of 5
Re: Mobile data issues
Hi williebhoy61,
Thanks for posting and welcome to our community 🙂
I'm sorry you're having some issues accessing certain sites, have you checked the phones parental control settings?
Alex_Rm
williebhoy61
  • 21
Message 3 of 5
That was what the problem was . it is now fixed but it should not happen Virgin mobile should advise you when you join that you need to phone to get the settings changed
Alex_RM
  • 4.53K
  • 260
  • 344
Message 4 of 5
Glad to hear this has been sorted williebhoy61,
I'm sorry if the parental control settings were not made aware to you in beginning.
Alex_Rm
enlli
  • 7.41K
  • 1.17K
  • 2.09K
Message 5 of 5
They can be changed from your online account.
