on 13-10-2021 20:14
I am on the EE network and the signal is just non existant. I can't make or receive calls in my house lucky if i have 1 bar. 3 bars at most jn my area. On your tv adverts you claim to be the best UK network, that is just a lie!! I want to terminate my contract as it has been no use to me for the past year and i wont be keeping it for the next two year when it is not fit for purpose.
Answered! Go to Answer
13-10-2021 20:29 - edited 13-10-2021 20:31
Assume you are with Virgin which running on EE, well that will be changing soon as Virgin move on to Vodafone.
However you don't make it clear if you are actually Virgin or EE. If the latter you are in the wrong place.
All networks claim they are the best in some way, something that should be taken with a pinch of salt. However, no network claims to have perfect signal in every nook and cranny of the UK.
As to terminating your contract, I have no idea what terms you are on but wanting to leave when you have been using it for 12 months won't cut it. That's what the 14 day cooling off period was for!
on 13-10-2021 20:34
Thank you for your reply, do you know when the switch might happen? I was with Vodaphone before and signal was brilliant.
on 13-10-2021 20:36
Between now and January I believe, but I haven't seen a definitive schedule.
on 14-10-2021 08:28
Hi @Izzymud,
Thank you for your posts and welcome to our community forums. We're here to help.
I am very sorry to hear you've been having some signal issues lately. How long has this been ongoing for? Is it only within your home that you seem to have this issue?
