kaz40
Mobile Broadband Huawei E5576-320
I bought a Huawei mobile broadband device on a 1 month rolling contract. Paid £39.99 as upfront cost. I got 3GB data deal for £8 p/m.  After buying the device I realized 3gb is not enough for me. As I am on a 1 month rolling contract I am free to leave in a month after giving notice. (30days notice req)
So I rang and asked to unlock my device, so that I can use it with a different network. First I was told, the request has been made & it might take abt 7-10 days. So I rang again to check up on it, and was told that the device can't be unlocked. So I questioned , whether is it allowed. As far as I know no network can lock their customers to their network only, unless you are inside the contract period.
Is this correct, Can virgin tell me I can't use the device with other network. Also i paid for the device upfront, it wasn't given free to me. Every time i call, I get different answers, or they do not know the answer. I just waste hours on the calls getting transferred from one department to another.
If I ask to complain , again there is no email or number for that from them.
Please advice.
Thank you
enlli
  • 8.01K
  • 1.25K
  • 2.29K
Re: Mobile Broadband Huawei E5576-320
Are you sure it's locked? I know with phones Virgin have not locked them for some time. Can you borrow a SIM on another network and try.
I suspect 789 don't know the answer to this one. I didn't even know they sold these devices
kaz40
Thanks for the reply. Yes, I tried Ee & three sim cards and it did not work.
Then when i put back the virgin sim , it did not work for abt half an hour. I have to call them to ask what was wrong, but again no proper answers.
Luckily it started to work back. Think I have to complain ,.
Thank you
enlli
  • 8.01K
  • 1.25K
  • 2.29K
It may not have worked with those other cards as the APN settings would be different. If I remember correctly they have to be set by using a Web browser.
