DaDo
Message 1 of 5
Messages and calls not getting through
Hi, my phone doesnt receive texts or calls on time. Texts arrive a day late and calls go to my voicemail without ringing. I need verification codes via texts to access my work emails. Very frustrating,  I'll be changing networks if this isn't resolved quickly.
Anonymous
Not applicable
Message 2 of 5
Re: Messages and calls not getting through
sounds like a signal problem. If you are getting no signal not much can be done. you'll need a network you can get a signal from where you need it
DaDo
Message 3 of 5
Thank you,
I'm living in an urban area . Very strong signal all the time
enlli
  • 7.4K
  • 1.17K
  • 2.09K
Message 4 of 5
Still could be a network problem not associated with signal strength.
Have you tried reregistering on the network? Do a network search and select any network but virgin, it will fail. Do it again and select Virgin. This should hard reset your network.
Also try https://myaccount.ee.co.uk/networkchecker/checkservice and see it it says anything for your postcode
DaDo
Message 5 of 5
Thanks, I didn't know about the network reset.
The tech people at virgin sorted it. Pretty quick too, in fairness.
Thanks again, VIP, much appreciated.
