SF3003
Loss of Signal
The last couple of days there has been intermittent loss of signal in my area. Others on the network have had the same problem. Signal here is normally very good. Is there anything that can be done about this?
japitts
  • 12.12K
  • 1.69K
  • 2.6K
Re: Loss of Signal
You can check with the EE faults site whether there's a known issue in your area here
Virgin don't operate the mobile network, they piggyback (with limitations) onto EE coverage.
