5oysterman2
  • 11
Message 1 of 12
Losing mobile signal at home
Hi, continually having problems at home with my mobile signal. I keep losing it completely & when i do get a signal it is not very strong. I get a good signal most other area's.
I've restarted phone, switched aeroplane mode on/off. Taken sim card in/out. Checked coverage in my area CO43XG & ok. I am now missing calls & sometimes friend's/family can't connect at all, or even able to leave a voicemail message. Regards Doug
enlli
  • 8.03K
  • 1.26K
  • 2.29K
Message 2 of 12
Re: Losing mobile signal at home
Looks like there was a problem in the area
enlli
  • 8.03K
  • 1.26K
  • 2.29K
Message 3 of 12
I've checked the OFCOM coverage checker for indoors and no 4G. The reason for that is Virgin do not have access to calls over 4G which run on 800MHz, a better frequency for indoor coverage. All your calls go 3G or 2G so thats the important coverage
5oysterman2
  • 11
Message 4 of 12
Thanks for the quick reply. I knew a problem had been sorted out by EE.
So if there is no 4G coverage at mine, do i just change my phone to 2G or 3G & that will sort the issue out?
5oysterman2
  • 11
Message 5 of 12
 just checked offcom & it says I have 4G indoors!!!!
enlli
  • 8.03K
  • 1.26K
  • 2.29K
Message 6 of 12
The OFCOM checker is showing questionable coverage on 3G / 2G It may improve things, it may not as the phone does not have to drop down from 4G anything is worth a try in these situations.
Long term you need either WiFi calling are moving to a network based on Vodafone or O2. Voxi or GiffGaff may suit your needs.
enlli
  • 8.03K
  • 1.26K
  • 2.29K
Message 7 of 12
We don't know what 4G coverage that is. Could be 800Mhz to which you have no access, or one of the other frequencies available
I left 4G out simply because you have call problems and on Virgin you can't make calls using 4G.
Gareth_L
  • 7.9K
  • 467
  • 877
Message 8 of 12
Hello 5oysterman2
Thanks for bringing this matter to our attention
Sorry you have had a few niggles with your connection
From what you have been advised already it seems to be sorted
Please let me know if you still need assistance
Gareth_L
5oysterman2
  • 11
Message 9 of 12
Hi Gareth, sorry to say it's not sorted. I don't have wi-fi calling on my phone. So it looks like I will have to change provider. Regards
Gareth_L
  • 7.9K
  • 467
  • 877
Message 10 of 12
Hi 5oysterman2
Do you mean the actual handset doesn't support Wifi Calling
What phone do you have
Gareth_L
