Joeau
Message 1 of 7
Losing 4G Signal
For the past couple of months, 4G has periodically dropped connection, either completely or to < 0.1 Mbps. This is frequent, occurring multiple times per day or in a single session, making mobile data unusable.
Prior to this year, connection was never an issue. Use of 4G on different networks abroad has been completely without issue. The SIM has been tested in a different phone and shows the same pattern.
The coverage checker shows good signal in the area, and again didn't have an issue until this year.
Is there any potential fix or should I change network?
enlli
  • 9.81K
  • 1.45K
  • 2.82K
Message 2 of 7
Re: Losing 4G Signal
Probably the change from EE to Vodafone as network supplier.
Coverage checkers can't take into account local issues which can be down to a variety of things.
If the phone works well in other locations then a move to an EE based service may be an option
Ryan_N
  • 3.66K
  • 157
  • 309
Message 3 of 7
Hi Joeau,
Thank you for your post and welcome to the forums.
Sorry to hear about the experience you're having with the network. We did migrate our SIM cards moving from the EE network to Vodafone, around that time is that when you've noticed the change? Are you having this issue in all areas you go to or is it just located to one spot?
Cheers,
Ryan.
Ryan_N- Forum Team
Joeau
Message 4 of 7
Hi, that sounds like the right time yes. It certainly occurs at two different locations ~ 8 miles apart, both relatively central locations with no reason for the signal to be impacted. As I said, it worked perfectly when on networks aborad.
Is this the quality of signal that can now be expected in city locations?
Travis_M
  • 4.57K
  • 169
  • 335
Message 5 of 7
Hi @Joeau
Thank you for the reply
Are these two places the only two where the signal completely drops off?
Travis_M
Joeau
Message 6 of 7
For the most part, but I can't say it won't happen in other places too
Ryan_N
  • 3.66K
  • 157
  • 309
Message 7 of 7
In regards to your question asked about the expected quality of signal - it isn't what should be expected no, but also we can't guarantee a 100% fault free service - we can try and help diagnose any issues so don't worry. The locations in which you mention, just to confirm are they the only places that you know of that you have the issue with?
When was the last time you had a new SIM card?
Cheers,
Ryan.
Ryan_N- Forum Team
