  • 10
Message 1 of 7
Locked out of voicemail abroad - PIN reset?
I have a voicemail but when I try to access it I am asked for my PIN. I don't remember setting a PIN but tried the two most likely numbers and have "temporarily" locked myself out of voicemail.
1) How long does the lock last? Can I unlock it from the web?
2) I've read both that there definitely is and definitely isn't a default PIN (7890) - is there? How do I set my PIN?
I would rather do everything from the web if possible as I have free WifI here but calling customer services will cost me £1/minute from Turkey and I don't have much credit left.
  • 5.48K
  • 765
  • 1.54K
Superstar
Message 2 of 7
Re: Locked out of voicemail abroad - PIN reset?
There is no default pin ☹️
Usual is to ring voicemail and set a pin while in UK before going away.
Ringing CS would most probably be a costly fruitless experience, only hope I see is that one of the Forum Team here may respond (a few days) and offer to set a temporary pin for you.
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only. Customer since 1993.
  • 1.6K
  • 68
  • 117
Message 3 of 7
Hello higgo,
Sorry to hear that, I will look into this for you, I am going to send you a private message if you can reply I can get that sorted.
Thanks Joe_F
  • 10
Message 4 of 7
Thanks Joe_F,
All sorted now. The message waiting for me was, of course, completely unimportant but I wouldn't have known that unless I'd been able to get to it.
  • 1.6K
  • 68
  • 117
Message 5 of 7
I will be sure to feed that back for you Higgo ^JF
Message 6 of 7
Im in Lanzarote & Iv'e recieved some voicemails & I think they are from my airline.
My voicemail keeps asking for a pin, which I haven't got set on my phone.
Can anyone help please?
  • 3.02K
  • 108
  • 159
Message 7 of 7
Hi mikey22,
Thank you for your post and welcome to the community.
Our apologies for any inconvenience with this. If the voicemail is asking for a pin then it would have one.
While I won't be able to find out what this is, I should be able to change this so you can access your voicemails.
I will private message you now so I can help with this.
^Martin
