Katiecat3
  • 10
Lack of signal
Had this issue for a while now.  Signal drops out and I can't get through to anyone.  Since I live alone and have to keep in touch with my mum who lives 80 miles away on her own and has dementia this is more than just an inconvenience.  When I ring Virgin it says the line is busy!  I can't call from my mobile as the call just drops out.
I am very unhappy.
enlli
  • 8.02K
  • 1.25K
  • 2.29K
Re: Lack of signal
Have you tried putting your postcode in here. Use the button for I have a problem
https://coverage.ee.co.uk/coverage/ee
As calls are dropping you will need good 3G coverage indoors
Gareth_L
  • 7.89K
  • 466
  • 877
Re: Lack of signal
Hello Katiecat3
Sorry to hear about signal dropping
I am more than happy to take a look at this for you
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
Katiecat3
  • 10
Re: Lack of signal
Thanks for your help Gareth
Bryony
Katiecat3
  • 10
Re: Lack of signal
Thanks for your help but EE say there are no problems in my area 😞
Katie_WT
  • 5.02K
  • 304
  • 572
Forum Team Manager
Forum Team Manager
Re: Lack of signal
Hi there @Katiecat3
Thanks for popping back - did you get your new SIM as per what you advised a couple of weeks ago and are you still having issues with your new SIM? I can see the new SIM was activated with no issues.
When checking your area, we can see that the nearest mast to your home is fully operational. There a couple a bit further out that have had some degraded services but there are plenty of other masts in the surrounding area to pick up any slack.
Do you only have this issue at home? How's things when outside - even in the garden, any better?
Have you tried your SIM in a new device at all?
Keep us posted and we'll go from there.
Katie - Forum Team
